Which one do you like more?
Oh ok, yeah I meant is the center or billet gloss. It doesn't seem glossy in the pic,maybe it's the angle. I would also get chrome amber bulbs to get rid of the little amber that's visible in your clear corner or some LED turn bulbs
No,you just have to get all 4 of them. 2 for the front and 2 for the back and they will work, but if you only get 2 up front, I think you'll get a bulb out message.
Alax is correct, you need to do all 4.... I mean I guess you could do one side (like both left or both right).... But that would look retarded anyways lol
Yeah, just swapping all 4 bulbs and thats it. Are you scared of resistors?
lol no i just don't want to wire anything lol, did you get red leds or clear for the rear turn signals? or it just doesn't matter
You would think that since your tails are red you could go with a white bulb and the light output would be the same, you can, but I read that going with a different color light than the lens will result in less output because the color lens will filter out other color lights more than the color it is. So going with a red light bulb on red tails will give you better output than red tails with white lights.
Our's are clear in the turn bulb part so we have to go with amber bulbs, unless we have gen2 all red tails. It's up to you what you go with though. Just saying
yea i'm gonna go with red, i think i'm get the rest of the brake lights too so i can start my led conversion
Yeah, I would get them all at once too. The led brakes are real bright, I love them. Remember to wire in some resistors though.
are you sure i won't have to wire in resistors for the turn signals since those are technically brake lights too, also where else will i need resistors so i know how many to order
Yeah, pretty sure the turn bulbs will work IF you install all 4, from what andrizzle said. Th reason you need resistors for the brake lights is because you're using one bulb to do 2 functions, running lights and the brighter brake lights when the brake is pressed. They work perfectly with the running lights off but when on, they wont have 2 levels or brightness like they should, so resistors are needed.
How to wire the resistors, 4 in total, 2 per bulb
http://www.lincolnvscadillac.com/showthread.php?t=68935
How are the turns brake lights? They dont turn on when you press the brake
The turn signals in my 04 work without resistors... However the front do not come on as parking lights... but I think it looks better this way anyways.
no bulb messages though.
yea nevermind lol for the license plate bulbs is says w5wl what bulb is that exactly?
Might need a resistor but since you like it that way, cool.I might leave mine like that too to show off the angel eyes more
license plate bulbs
2 HID WHITE HIGH POWER LICENSE PLATE LED BULBS 194 168 158
The top 4 work
http://www.v-leds.com/Shop/Control/fp/SFV/32481
alright everything ordered except the resistors, i'll pick those up some where else thanks a lot guys! i'll eventually do the interior but not yet, i still have to do my exhaust
license plate bulbs
The top 4 work
Yea, honestly the front LED bulbs are too bright to have on full time... It would take away from the angel eyes alot IMO. The side marker inside gives the perfect amount of amber
