Wheel offset +35 plus 20mm wheel adaptor
Seamusmc
Mississauga
Hello,
Could anyone hazzard a guess as to whether this set up will work with a 245/35 tire on my LS?
My current set up is a 45+ offset with a 245/35 tire. If I understand it right, compared to my current set up, with a +35 offset and 20mm adaptor I will be adding 30mm???
Any comments would be appreciated!
Thanks.
Gonna stick out past the fender. How far depends on wheel width.
Your wheels will be sticking past the fenders as Pektel said. I have 35mm 20x8.5 rims on my car and they are very flush with the fender. If you do this, you will not be able to lower and you will surely rub everytime you hit a big hump in the road. Why are you adding adapters? Are you buying a wheel with another bolt pattern?
Hey Guys thanks for your responses.
Yes, I am looking into getting new rims with a 5x114 bolt pattern. I'm thinkin if I want to go this route I will probably have to swap hubs or get the hubs/rotors redrilled.
I know the Marks can swap hubs with a Cobra...
Yep the rims were great but..they're all bent out of shape -- time for some new ones. Hence the post.
Hey, look at that, looks like you're not as unique as you thought pete. :p
That sucks that they are bent, too much to fix or what?
Actually, I thought he had sold these to 02V8Sport originally. Guess I was wrong.
