radio loosing power and shutting off
stallone 81
New Jersey
i installed leds in my front map lights a few weeks ago and today in my car my gf was looking for something and turned it on for a min or 2 and all the sudden all the lights on the radio shut off and the radio itself shuts off. i turned off the lights and it comes back on i then do it again and it shuts off but this time the radio doesnt turn back on. is it that the leds are using too much power or is it a fuse ?
Led's use less than the filament bulbs. Weird stuff going on there.
ground short
check your work for a ground short open wire or wires crossed. sometimes you also get some weird stuff going on when the battery is going bad, or clockspring is going bad. any other symptoms? I enjoy working on old radios, and you find that the capacitors fail as the radio ages, I swap out the capacitors to bring it back to life. However, I've never heard of an LS radio problem. if all was working before you put in the leds and now it fails, i would check your work first.
the radio is working fine as of now and no other weird stuff but i still have no idea what coulda triggered that last night
It's possible that your battery is getting weak and its voltage got a little low while the key was on with the engine off. (I'm assuming that the engine was off when this happened.)
make sure that a wire didnt get pinched when you put the dome light back together
nah the car was on and i was driving
eh stallone.....
loosing : present participle of loose (Verb)
1. Set free; release: "the hounds have been loosed".
2. Untie; unfasten: "the ropes were loosed"
losing present participle of lose (Verb)
1. Be deprived of or cease to have or retain (something): "I've lost my appetite".
2. Cause (someone) to fail to gain or retain (something): "you lost me my appointment at the university"
