seionkelley
Are the aftermarket HID's for low beams only?
You won't need any high beams once you install the Low beam HID's ...
My set are so bright much brighter than my high beams ... Love them ... I can see at night LOL ...
I have them in both the way to fix the problem of cycling them is to modify the multifunction switch so that high and low are on at the same time this helps the lows only but it will save the bulb and balast from what's cAlled a quick strike shortening the life of the units. But the guys are right you wont need your high beams if your housings are in good shape, your lights are aimed correctly, and you have a good set of hid's
