Disabling squat feature
Ed Hall
Ventura
How do I disable the squat feature whenever the car is parked? Will I disable that feature if I install another switch that turns off the air suspension thats located in the trunk?
turn off the switch in the trunk when the car is at normal height..if your bags dont leak it will stay at that height.
That's the simplest way.
You could put in a switch in the passenger cabin in series with the suspension switch in the trunk.
With both switches closed, the air suspension will operate normally. With either switch (or both) open, the air suspension will be deactivated.
You will have to press 'reset' at the suspension warning from the message center though.
I have a switch that runs 12v to the trunk, it currently goes to nothing
can I just cut off the output from the factory switch and connect my 12v switched wire to it?
it's kind of awkward to get to with a meter to check, figure I might as well ask
No, the switch goes to ground. With the ground removed (switch open), the system is deactivated. I haven't looked, but I'm sure you could wire in an interupt switch to the proper circuit at the harness connection to the suspension module. Just find the proper wire, snip it and extend the wires to a single pole switch and you're set. While you're at it you could disable the check air suspension circuit to the message center if you wanted.
