stallone 81
i want to put a timer on my reverse light almost like a 2 or a 1.5 sec timer so that every time i switch into gear it doesnt trip on the reverse lights how can i go about this ?
just unplug the bulbs, how much do you actually reverse with someone thats needs to be aware by reverse lights behind you
You realize they are there so you can see backing up, right?
Unless you are running an HID kit in the backups. Then why would you need this?
And to the other user, yes they do
Illuminate breifly when passing through the gear.
I just checked. They don't illuminate on our 2000 or 2006 LSes when switching from "P" to "D".
then your car is wierd lol jk they illuminate if u shift slow enough, like a half second in the reverse gear
With that I concur. I, nor my daughter, dally through "R".
yeah but you might now do it all the time but you prolly do once in a while. if i was to do this mod if i would need a delay because if i kept switching them on the ballasts and lights would go
shift faster, and how often are you going through R? it shouldn't be that many times a day, most HID companies now have lifetime warranty's, i don't think that it is worth the trouble
any circuit you would have to use for the delay would trip the burnt out light warning on the dash (if those bulbs are monitored) which could be even more annoying
you might be able to use a DEI 528T pulse timer relay, i believe that it would do the function that you are looking for. then again it may just delay how long it takes for them to come on (the lights will still come on for a second just a little later)
A delay circuit should be that difficult. Do a Google search for DC power delay circuit and you will get a ton of results. Hopefully, one of those will either have a kit you can buy, or a premade solution. You might check a large distribution company like Grainger.
why not make it toggle switch so when u want them on there toggled on or off.
