Trying to buy a blower....hit a snag.
i've got extra kb pulleys if you know what size that you want.
Whatever the 6-7psi one is. I figured KB was the only place to get those oil line plugs though too. I am not sure what diameter pully that is but id imagine it would be their largest.
I wonder if 03/04 Cobra injectors will fit? 39lb should be enough for what I want and they are cheap. Also thinking if I should upgrade to a Cobra MAF.
They will fit but you'll need adapters , they have EV6 connectors and your car has EV1 injector pigtail.Get 42lb Lightning injectors [lime green top]
You are my hero! So Lightning injectors will drop right in with no adapters? Cool, I will hunt now.
That's correct , no adapters needed for Lightning injectors.
