you cant loosen them with a torques bit, you have to break the nut loose on the opposite end first, you'll snap them torque's bits left and right if you try to loosen the bolt with just that, break the nut loose first.
one of them on each side is fairly easy but the opposite side isnt because the head of the bolt is inbound making it tougher to get the t-50 in it! its easiest to unbolt the axle nut, unbolt the upper control arm bolt and drop the knuckle down and pull the axle shaft out of the way first, with the axle shaft in the knuckle, it causes that inbound bolt head to get jammed againt the cv joint then you cant gen the bolt out!
I got the knuckle off and the halfshafts out.
The bolt I am talking about is on the side of the LCA closest to the differential; specifically, the bolt on each LAC closest to the driveshaft. I have broken one impact socket trying to get it (a cheap, harbor freight impact socket). I don't have an impact wrench...
The bolt closest to the gas tank with the plastic or rubber cap on it.
