Alexbougie
V8 forever
			My office is in Buffalo.
Your lame attempt at humor failed.
Prior to my 06 LS, I had an 03 (Gen 2) LS with the V6. I liked it. The motor was very smooth and the power flow was very good. It would not beat a V8 of course, but I would gladly accept that for better gas mileage.
The V8 in my 06 LS was a good engine, but it would ping like crazy on anything more than half WOT. Even on premium fuel with octane booster! The V6 would not ping at all.
i had the v6 duratec engine in my old 88 taurus and for longativity they last nontheless but for mods and speed V8. I have an 02 V8 sport and the only thing ive done to it is plugs and coils other than that just oil changes. The v8 is flawless if you take care of it. Plus it sounds better with some nice mufflers.
your V6 only had a 1-2mpg difference in gas consumption vs the V8, so what you said is illogical!
Could be because there are far fewer V6es out there.
I have a 2000 V6 and two 2006s. Had I known then what I know now I would have purchased the V8. The V8 also has a higher resale value, if you care about such things.
I don't think you need to use premium. The manual recommends 91, which is not available where I live and I have been told by a few people that the 83 or 87 is just fine, but I just use the premium because it makes me feel better. Ha. I am sort of OCD and like to worry and panic over nonsense. I used the lowest grade gas a couple times and absolutely nothing bad happened, but I felt troubled. Ha. So I went back. I have a problem!
There is a lot of controversy over the whole gas thing on the internet. Just like with the Mazda RX-8. Some people say they have never used premium ever and the car is as happy as Larry and then other people say if you use 83 just once the 8 will explode and kill your entire family in a horrific fireball.
There's nothing wrong with the V6. I think you'd be just as happy in one and it sounds like you'd have less worry on your mind in one as well. And really, that is the most important thing. If you're constantly worrying about your car you're not enjoying it and then you're better off not having it. If that makes sense.
Octane recommendations
Your vehicle is designed to use
“Premium” unleaded gasoline with
an (R+M)/2 octane rating of 91 or
higher for optimum performance.
The use of gasolines with lower
octane ratings may degrade performance. We do not recommend the use
of gasolines labeled as “Premium” in high altitude areas that are sold
with octane ratings of less than 91.
Do not be concerned if your engine sometimes knocks lightly. However, if
it knocks heavily under most driving conditions while you are using fuel
with the recommended octane rating, see your authorized dealer to
prevent any engine damage.
91 (R+M)/2 METHOD
Maintenance and Specifications
293
