mistermaclincoln
My 95 LSC won't start and when I turn the key on I don't hear the fuel pump. I had just fulled up. Any takers.
You are correct, I did have a tank/clip problem and that was solved by replacing both clips with new ones. The car has ran fine up until today. I have driven with the 255 Walbron for almost one hundred thousand miles. However nothing last forever. I am going back to the car now and see if it will start sometimes you never know.
DId you manhandle the gas tank with a BFH yet?
Well, I just thought I would tap and knock on the fuel tank to see if I could something to work and sure enough the car started. I am going to pickup a fuel pressure gage and check the fuel pressure, what should the pressure read? I remember this kind of nosense happen in my Mustang and it ended up needing a new pump but like you said you never know about these cars.
Let me know your thoughts.
Let me know your thoughts..
I have gotten 3 different cars to their respective homes using just this method. If you can whack on the tank with a rubber mallet and the car starts, it's the fuel pump no two ways about it.
96-98 255 Walbro,
