invisiblem0nst3r
when i floor it and it shifts it will churp into second and jump foward hard
All marks do that, nothing special sorry
Mine will chirp into second real nice if I shift manually, if I just nail the gas and let it go on its own then I only get a small chirp.
I have been told that these transmissions dont like to be maunaly shifted to get some scratch, they just wont hold up stock.
any opinions on that.
As far the chip, I sold the comp from my parts car and didnt even check if it had one, how could I be soo dumb. i forgot who it went to but Im pretty sure it was someone here.
have many people found chips in there marks when buying them from regular(not lincoln nuts) people?
Okay so where were we.....
How can you tell if your comp has a chip
easiest way to tell...
scan it for trouble codes.
if you get the "bad pcm memory" code it probably has a chip.
eec iv cars cant store a trouble code with a chip in
Here's a simple test for a chip ... If your Mark VIII goes over 135 mph ... then you have a chip ..
If you get up to 120 or 125 and the car just comes to a stop ... no more go you don't have a chip ...
undo the 4 screws under the steering column that hold the panel that would be directly in front of your knees. remove it. in between the e-brake & the brake pedal you'll see a metal box with a gazillion wires running out of it. On the back of it theres a 2" slot. They come factory with a plug in the slot. It covers the port that the chip would go in.
it's esier to remove the ECU (box) & just look at the back of it. If it still has the plug in it, chances are that there's no chip. But pull it out & look to be sure.
Scanning for codes probably being the easiest. Take it to a place the scans for codes for free and see what happens..
they usually dont scan EEC 4 cars, only obd2.
you can do the "jumper wire/ count the CEL flashes" method which is free.
