TDUB
Ok so technically it's not a Mark but it's basically the same engine so I figured you guys would know... I'm in the midst of cleaning the IMRC's on my Cobra but I've run into a road block. I can't seem to get the coolant crossover tube off for the life of me. I've pulled and tried to wiggle it out but nothing seems to work. The tech articles I've found for cleaning the IMRC's have almost nothing on how you get the damn thing off. Also, I can't get the bolt off to siphon out the coolant from the crossover and all I really found online was to torch it and hope you don't screw it up too bad when you get it out. Do I even need to siphon it here or is there somewhere else that will work? Also, I'm wondering if anyone knows whether or not any of the Marks use the same cruise control cable as the 96-98 Cobras?
