mark viii PCM and one piece driveshaft they worth anything
87TTOPGT420
South Woodslee, Ontario
I have a couple w3z2 PCM's around are they worth anything? I read somewhere they have more agressive spark at WOT, and a higher shift pressure and a higher redline and i think no speed limiter am i correct? Are these things worth anything? I have 2 of them for sure...w3z2
Also have 1 piece driveshaft from a 1993 Mark viii i pulled today...what are these things worth?
those are some solid offers, thanks guys...but honestly? are these PCM's worth anything? like $75 or what? Im sure the 1 piece driveshaft is worth something...i would think $125 or so...am i out of line?
Drive shaft $75-$100 seems to be the going rate. I have no idea about the computer.
I sold my computer with a custom tune in it for $75ish and I also paid $125 shipped for a 93 shaft with fresh u-joints and a rubber glove. :D
to someone that will never buy a chip, those pcms will give them a little more performance...yes
most everything you said about that pcm is correct
but once a chip comes into play all bets are off and all the pcm's are equal.
but comparing a stock unchipped w3z2 to a stock unchipped dza1 the difference is night and day.
so in other words i should make sure my driver has the w3z2 then before i go and off these things...i would be satisfied with $50 thats worth my time to yank out
yes, and be sure you dont confuse w3z2 with w3z3, they are not the same
another question>will that 93 pcm work for my 94 or is mine the same one built in the month of 5/ /94 cause I heard that the 93 and 94 are a lot a like and if not will it be worth changing out and what kinda improvement will It be????
i'd be willing to pay 100 including shipping for that driveshaft.
pm me if you are interested.
