My transmission extension housing seal was leaking tranny fluid, and the dang oil was running straight to the transmission mount which got messed up due to it.
Seems like a common problem to have, my car has 150k. Neither Ford nor Lincoln sells that seal I did ordered at Ford, and the seal is not the one in the tranny. If u ever run into this problem, the solution is Napa (thank God for creating NAPA !!)
The new seal is in already, on the pics the Ford seal, and over the Napa box the original seal.
The OEM seal is made in Brazil, and the one Napa carries is made in Japan
[/IMG]
[/IMG]
My car has a WEIRD and hard knock somewhere in the drive train. WEIRD ! I does it sometimes when Im standing in neutral and press the clutch. Sometimes it does it while releasing the clutch pedal after shifting. Sometimes I press the clutch pedal and I feel like something is loose or something, including a metal noise from underneath the car. I thought it was the tranny going up n down due to the messed up mount. But Ive already replaced the seal and the mount. NOTHING changed. Now I assume its either something with the drive shaft or the differential. Any thoughts??
5Spd LS's pictures r ALWAYS welcomed !!
