what would i need to do to wire these to batteries to the car charging system.
all you need to do is ground all the batteries, and then run the power wire from the stock battery's positive terminal to both aux batteries positive terminals, if you want to use a battery isolator it will go inbetween the factory battery and the first of the two aux batteries on the +pos line, and then the amps will need to get connected the the aux batteries AFTER the isolator.
would it damage the charging system if its mroe then the rec 650 cca?
i'm not going to get into a nother discussion about batteries vs alts again, but i will say that I BELIEVE that adding extra batteries with out upgrading the alternator will put extra stress (above what the sound system will do) on the stock alternator and cause it to burn up quicker
is there a way to just give the charging system 650 cca? would battery isolatros come into play here and
the charging system is where the power comes from (alternator), the isolator just keeps power going from the alt to the batt and not allowing it to go back to the car, so if you have an isolator the stock battery will be the only battery that powers the car (unless switched over to allow power to flow both directions of course)
what about some splitters for the vent tubes. i checked the threads but nothing talks ab out these type of batteries just the optimum batteries or regular batteries.
just about all batteries need to vent in emergency situations (i do not know for sure about kinetik's) but i would not reccomend having a battery that *could vent* not being able too, as far as venting goes you could always get a battery box (like the kind that they make for track cars) because they usually have there own vent system plus they would give you a mounting solution for the new batteries.
if you dont mind me asking, why three batteries (one of which being stock) it would be cheaper, and a lot easier to get one larger battery, and replace the factory batt with it, not to mention the amount of space and weight saved.
