Can i use a 2001 mustang gt hub's for a swap?
STANKNLINCOLN
La
A local guy said he will give me a good deal on all the front suspension i need off his 01 mustang GT.Before i go check it out i want to double check and not waste my money.
they will work for the front. for the rear you need 99-04 cobra hubs. Front hubs really arent that expensive new, like 40 a piece.
You are right about the fronts.. However. You must use 99-00 cobra hubs in the rear because 03-04 were 31 spline. You should send them out to get redrilled it's 75 bucks shipped to him and back. I will find the order form and email it to you if youre interested...
Yea shoot me that info please.Will my rotors and calipors still work?
Hubs are all the same @28spline throughout all IRS Cobras 99-04.
Get with Ed from the link above, the deal can't be beat.
Yes. You will have to redrill your stock rotors using the redrilled hubs as a template and everything will be a direct bolt on. I've been running redrills and havent had a single problem for 10k miles with about 100 track passes and driving daily.
