Looking for a vacuum leak I was going to use some carborator cleaner. I believe that's ok but not sure. Also, I have some MAF cleaner maybe I could use that?
Also, ran a bottle of sea foam through the car yesterday to clear up an error. I bought another can to run through the gas but was going to put it through the engine (another one). I imagine it's not going to hurt anything, but figured I'd ask where best to use it. Oil, gas or engine. The directions on it say to put 1/3 in the oil after a new oil change or a 1/3 in the engine. Might just do both.
Getting a p01740 error, either I have a vacuum leak or some bad O2 sensors. (if I'm lucky)
edit: also, quick question. The rear dif. locks up around 38mph right. I don't have my radio hooked up and am hearing quite a lot of what I think is wheel bearing noise. How hard are these to replace? What do I need to take to a shop to get pressed? Are hub's expensive? I have 2 studs in one of my back tires that have sheered off. I'm thinking that hub needs replacing.
