For those that don't know...
The door sticker is the correct answer, no matter what tires you have. It is the pressure the car was designed for that gives the best compromise between handling, comfort, safety, and mileage (not in that particular order.)
It is nonsense to say that the pressure on the door applies only to the stock tires. Don't believe me on this, look it up.
Outkast, really??? a troll????
a little common sense and he could put it in his sig..![]()
is this true for totally different wheel and tire sizes? wouldn't tires of different sizes require different amount of pressure to keep them properly inflated? so even if you have something like a 235/25R20 the pressure should be the same as a 235/45R16(not saying this is the actually size, just a guess)?
Hah wow. This is a :q:q:q:qing pointless thread, as is #1 a pointless member;Nobody likes.
Of course, all bets are off if you change tire sizes. In theory, it is a safety violation to put a tire size on that is not listed as valid on the door sticker. I don't think that any areas check for that though.
I wondered why the f*ck it said attached everytime, and had a line under it like a sig....I didnt think he was that desperate to post that picture in every post....WOW
