yeah, just thoughtI'd rub it in a little lol.
IIRC, this is the list of what I needed:
LSD from an 04 mustang GT (28 spline)
gasket maker
pattern paint
motorcraft 80/90 synthetic diff fluid
motorcraft friction modifier
new axle seals (figured why the hell not, since it's already out on the bench)
new ring gear bolts
shim kit (the 8.8" shim kit will work. I bought it without knowing for sure)
I think that's it. there may be something else though that I'm forgetting.
A specialty tool you may not have is a dial indicator. You can get one at Harbor freight for about 30 bucks. (15 for the dial indicator, 15 for the magnetic base).
Be sure to have a shop manual to determine the correct torque specs too.
