2002 LS Not getting Fuel (Need Help)
Sanscuba
San Jose
This car sat for 8 months and when a new battery was installed and has 84K mikes on it.
it was not getting fuel and was blowing the 15 amp fuse driving the primary fuel pump.
I replaced the Primary Fuel Pump in the gas tank and the fuse and the car starts and idles great when cold.
But when you give it gas it stalls and bogs out above 2700 rpms . So I replaced the fuel filter and the same still happens.
It will dye out drive it around the block 2 times and to restart it takes cranking it over much to much.. The hotter the car gets the worst is runs and idles.
Connected a OBDII and the code reads PO 190 Error (Fuel Rail Pressure Sensor Circuit Malfunction)
The pressure on the rail is unknown but when at idle and depress the gas shoot out like it has pressure.
I connected to my ears like what a doctor has to listen to the engine for vacuum leaks and none found.
This is a fuel delivery issue and at this point I need help. I been out of work for some time and need this car to function
I don't have the money to give to the dealer and hope to find a local expert.
Sanscuba@hotmail.com
I wouldn't put my number on here. There are alot of inmature people on here.
Do you know what your fuel presure is @ the fuel rails? Sounds like your fuel presure sensor is bad or it's good and your not getting the proper fuel presures
I'm not an expert with gas engines, but I do my fair share of maintenance. I may be able to help.
right - is sounds like a fuel pressure regulator or a vacuum issue at the FPR.
who the hell would call san jose?
