Andrizzle
Following the recent thread about cutting into your hood to allow heat to be extracted, I got curious and did some mocking up of adding vents into the Wiper Cowl.
The squares would lead directly underneath the strut bar and on both sides of the engine block. I also used this time to inspect how the water is handled off the cowl and off the wiper holes. The corners of the cowl lead off into little ducts that spit the water and debris to the ground. And the wiper holes lead down little spouts that pour directly into the engine bay. So that right there tells you that a little water coming in from that area into the back of the engine would not be a big deal (minimal water).
Also the vent design I had in mind would have a lip against the bottom side of the cowl where water pools up and runs either left or right that would prevent any water from just straight up draining into the engine bay.
The orange squares are roughly the straightest parts of the cowl surface.
So to see if the mod was even worth it, I wanted to see temperature comparisons from under the hood.
___________________________________________________________
*Each lap consists of roughly, .5 mile of Highway (75mph); 2 miles of city streets (35-45mph). With stoplight traffic identical to each other (I made sure of this to not skew readings). Air temperature outside: 79°F
**Transmitter was not moved in between laps.
***Also I want to add that, "Lap 2 Start" picture is taken when I had the hood open, however the reading displayed on the Temp. Station is taken with the hood down (there is a 60 second delay in between each reading). I forgot to snap a picture of the starting temp when I went back under the hood because I couldn't remember if I took a tool out of the engine or not (lol paranoid), so I took the photo real quick before the new temperature reading overwrote it.
****When it says 'operating temp.' that means I took the reading @ the exact time the car read the normal op. temp.
*****I did allow cool down in between laps, neither of them are from a cold start. Like mentioned, I let the car idle to normal temp. before starting each lap.
With Cowl:Average: 137.5°F
Without Cowl:Average 110.9°F
Comments: Obviously with the cowl is stock normal driving. But I want to mention that when I had the cowl off and was @ stoplights or sitting idle. I could physically see the heat waves rising up in front of the windshield. And when hovering your hand over the gap, there is some major heat being pulled through. I would say the difference is pretty extreme when looking @ compared idle temps; think of all the time you sit in traffic in the heat. Also it was only 80 degrees today. Think if this was on a day of 95+. That is alot of heat!
I am still not sure if I want to cut into my cowl or not, I will think about it some more.
Thanks for reading!
Thanks for reading!
