Gas cap door won't open
Asim
Toronto
So I know of the manual puller, but has anyone else had the button stop working. The trunk release works fine.
i have a similar problem too, but my trunk button doesnt work anymore but my gas one is still fine, ive checked the fuses and and i know its not the selonoid because my button on my fob still works. keep us posted
you gave 3 possibilities, acuator, fuse and loose wire
In this case that is apparently true. For the benefit of anyone else that may experience this problem, I'll throw out a fourth possibility. The one on my 04 stopped working a good while back. It was just a mechanical issue. I sprayed grease on the release, and it has worked fine every since.
damn, i should have suggested that one too, hahaha but your right , sometimes latches and things get stuck
I had my gas filler door not latching, found the gas cap tether was interfering with the latch, moved tether works fine.
So sorry for the delay.
It was the actuating-fuse-release tab.
I'm kidding.
It was the fuse.
thats an easy fix, i wish thats all mine was. does anyone know of something i could check for my trunk button no working? ive checked fuse connection to the button, is there any other connection anywhere that might o come loose
