Had the manifold volume changed to 10L and the air charge WOT correction to 1.9... the timing is good at idle now (10-12 degrees) and the car idles perfectly but it still has no power off the line. So I need to install that 3500 9.5 converter... so if you delete your IMRC's make sure you have a high stall converter. I thought my 4.30's would be enough but I was wrong...
