Running Hot
Ls208
pocatello
So ive noticed for that last couple of days my car seems like its been running quite hot. not quite overheating but it gets close. the needle is right ubder the last white line. im not sure what it could be. the thermostat possibly? i checked a few pervious threads but all those talked about actually overheating. i also thought it could be the heat but its onyl been in the mid 90s latley so that didnt seem to be it. Any thoughts. or is this a normalrunning temp and i just havent ever noticed or is it too high. thanks in advance
It's not a normal temperature. Both of mine never go past the half-way mark. It's been around 100 here.
yea thats what i thought, my coolant was pretty low when i checked this morning but it doesnt seem to have done anything after filling it. and my coolant bottle has been replaced a few months back so there isnt a crack in it. so maybe my thermostat is going out. thats my only guess.
Run the engine to normal (or above) temperature, then squeeze one of the bigger radiator hoses. If it squeezes (isn't hard to press), then you have a pressure leak somewhere. If so, that has likely allowed air into the system, and that is the main cause of the overheating. You will need to find and fix the leak.
On my 04, one of the smaller hoses just pushed itself loose once. (The spring clamp wasn't holding tight enough.) I had to put a screw type clamp on to hold it.
are you talking about the big hose to the left of the radiator? if so then that hose was very easy to squeeze.
What I think is BS is that mine overheats on hot summer days in sport shift mode. I mean temp guage agreeing with the alarms that show and the coolant smell. I'm not talking about hard driving, just slow inner city traffic. Dealer said it was a normal expectation. Doesn't do it in auto, just in sport shift mode. What a crock.
Hope you get yours figured out.
You have a leak somewhere then, and it will have to be fixed, and the air bled out.
damn, that sucks. it sucks even worse because im not even at home right now. im in cailfornia till september so i dont know of any good honest shops around here that will actually help instead of trying to get me for every penny i have. but probably every shop in california is gonna be like that due to their current economic state. anybody know of any decent shop in citrus heights ca? or around sac?
and alo wheni take it in do i say i need to check my pressure system for a leak? is that what its called.
no leaks were found so the mechanic recomended changing thermostat and flushing the radiator. so im getting that done and keeping my fingers crossed that it fixes it.
Did they do a pressure leak down test? It should hold 15 PSI.
honestly couldnt tell ya, all they said was they ran tests and said all the hoses were fine. so he recomended replacing the thermostat and i thought that was a good start being ive had the car for about two years and havent dont it myself and have no knowledge of it ever being replaced. and he also is flushing my radiator to check for any plugs. so we will see if that works. and by the way thanks for your help man
it was the tstat just so you know. and yesterday was 110 degrees so it was a great test to se if it was working correctly. passed with flying colors.
Mine is noticeably hotter after some driving in SST too.
The culprit may have been the tstat. It could've also just been air in the system, and the mechanic's proper filling procedure eliminated the air from the system.
Glad to hear it's fixed.
