NickT88LSC
95 Mark VIII, a/c stopped working and no cooling fan, from reading other post seems like that VCRM correct??? I checked fuses-all good, swapped relays around - no change. I checked low pressure switch-has voltage, jumped across it-no change
So does anyone have a known good one???
Also, how is the connector held to the module??? By a center nut like ECM'S??? If so, what size, cause I tried some sockets and nothing seems to fit. I tried also getting the lower bolt out of the control module to bracket and no luck, bolt and nut are spinning.
