kustomizingkid
HAHAHAHAHAHAHAHAHAHAHA.... so now we know... well when you buy those expect to cut... a LOT...
That's a classic!
*vizualizes KK struggling with two sets of frame end bushings*
lololol - No wonder some major trimming was required.
I'm just happy I don't have to feel like an idiot any more![]()
well i just inspected my front end i need sway bar links,lower control arms,strut rod bushings on both ends.I had one question i can do all those things but i wanted to know how to change those inner tie rods?Which brand is best i think im going to order from rock auto?
LMAO!! thats hillarious! epic fail!!!!! lolol
A big :q:q:q:qing crescent wrench and some swearing...
thats about it, i have a inner tierod toolbut all the same. remove outer tie rod end, remove inner boot, remover inner tie rod end, to install reverse procedure.
You forgot the part about the lock pin (rivet) he has to drive out and install a new one. I guess you could just shear it off with the wrench.
max
ever do a probe on jack stands... .
