starfox86
Rear camber is not adjustable.
Thank you for this info!
It is. You have to use a set of cam bolts, but it can be done.
Did you take that to a shop to have it done? Or do you have access to a rack to do that yourself?
They should have been able to adjust the rear camber. And those rear toe angles are still way off. I'd have made them fix that. I don't care if it's "within range" if you spent money to have them adjust everything, it needs to be perfect IMO.
i have eibachs as well and was told the rear camber is not adjustable ,,period have the cam bolts for the front.. they charged me for four not sure if four is needed.. if this can be done as well in the rear that would be great on my tires.. anyone first hand knowledge?
sorry to hear. After I replaced the rear "tie rod ends" and sway bar links, The car is MUCH better on the road. It still pisses me off sometimes though when it feels like the wind is blowing me everywhere or when I hit a bump or I am on uneven road the car likes to go its own way (not strait).
+1 my eibachs make me feel like I'm in a 5 series BMW
You have a non sport right? I would recommend stiffer springs and or a lowering kit, I have a sport but the lowering kit made one hell of a difference in the ride quality.
I have eibachs with new shocks in the front. Maybe I need to replace the rear shocks also
Did you swap out your shocks as well?
