Hemihed426
I havent posted in awhile mainly because I was so disgusted with my car that I had quit driving the damn thing because of a wicked pull when braking. I've replaced everything from pads to rotors to calipers. I put new upper and lower control arms on about a year ago when I did the coil swap, strut rod bushings and tie rod ends. I bled the brakes endlessly, replaced brake lines and ultimately got pissed off enough to walk away from the thing for awhile. I finally decided to tear the whole front end apart and investigate just what was going on and what I found really stunned me when I saw it. I pulled all the control arms off and found my 1 yr old TRW lower control arm ball joint completely frozen in place. I pulled the other side off and it was fine but I carried both of them back to Advance where I got them and raised enough hell that they gave me 2 brand new ones.I re-installed everything and no pull. I can't tell Ya'll how many hours I'Ve spent chasing this problem so if Ya'll are having a pull under braking check those LCA's even if they are new.
