98CobraStarLSC
Have you run it at the track roadboss?
Thats a nice setup, are you running b head or c?
I'm pretty sure he's running C heads as KB doesn't make intercooled supercharger kits for B heads
It's spelled "response", not "responce".
And if every... responce (as you call it) I make is negative, then you either a:fail at reading comprehension (we can see you already fail at writing skils), or
b: you are pulling these stats about every comment I make being negative out of your rectum.
Personally, I'm inclined to go with a little bit of both "a" and "b".
As far as the... respect you may have for speaking my mind... That's nice. But frankly, I really don't give a rats arse about your respect for my speaking my mind.
Any other rants you'd like me to respond to? If you do have more, PLEASE, make them legible, OK? Like, for example, "u" is a letter, not a word. If you're too lazy (or too damned stupid) to not be able to type in complete words, then you, again, fail at arguing.
Now, go look at some shiny cars and start dreaming.
WOW!!! that would look great under the hood of my Gen II!!!
does your tune pull the timing for you abraham?
holy shyt!![]()
yep 14 degrees i think?, but ive run it with stock timing. However, when I did run stock timing I ran step colder plugs with a smaller gap.
