Foglight Question for a 2000 LS
RollinLS
TBA
I plan to replace my foglight bulbs with Sylvania Silverstars. How do I get the foglight out? I need it out to do another mod too.:rolleyes:
The bulbs come out from the rear. They twist out just like the headlights, only they are much easier to reach.
I thought you just had to twist it 1/4 then they pop out?
He wants to also remove the housing... That's why he needs to remove the 3 bolts.
Josh, I should have the new mods done by our next get together. No one here will like them. Oh well. they are strictly for show purposes anyway.:rolleyes:
THIS may help...
...the three bolts on back are taken off with either a 7/16th or 11mm wrench or deep socket.
ALSO....if they don't pop out easily after removing the screws, there is ONE vertical/up-down screw on EACH light assembly(used to adjust aim) that has a spring on it, for those you need a philips/+ screwdriver to tighten, so that the assembly contracts(?!?).
sorry guys... :shifty: I'm a detailed kinda guy!
