Mark VIII Crankshaft Question
I'm pretty sure all Marks are a 6 bolt crank.
There is 6 bolts going from flexplate to crank.
FYI For you guys thinking on building a motor, I had to go with a 8 bolt Mach 1 flywheel with the forged stroker motor.
No ,you didn't use mach 1 flexplate.Auto Mach 1 has the same 6 bolt crankshaft as Mark viii.
