You can't replace the strut cartridges in the air struts... well that's kind of a lie... but to do it you will need to cut the old ones out and weld new ones in, and that is not an easy or safe thing to do.
You can't replace the strut cartridges in the air struts... well that's kind of a lie... but to do it you will need to cut the old ones out and weld new ones in, and that is NOT an easy or safe thing to do.
t-birds have coil spring struts, you have air ride struts, you can put t-bird struts in if you want to lose your air ride. otherwise call ford and get new struts, or call arnott and call them again a week after you put theirs in your car!!!
" jamies98lsc " that is a busted strut, the bag is fine, sure it just looked crooked like you said, but what happened is the shaft inside the strut is busted, it happened to a mark i had in my shop once.
" Jamie, You were right on (again ), it definitely busted, thanks! "
top quality not even a full 3 months old and look at it!!!!
