? about woodkit from woodview
flyboiz08
Havelock
are the pieces from the woodkit simply just adhesive wood strips... or are there whole pieces that need to replace the other stock trim
is there any way to get actual wood pieces... cuz wen you think about it 350 dollars for wood stickers is rip off
Maybe your going to the wrong place, try LS KONCEPTS $168.99:
http://www.lskoncepts.com/store/lincoln-ls-dash-kit-p-58.php
And they are more than wood stickers, I like mine and get a lot of complements even from the Lincoln Dealer service people.
Easy, need to clean surface well with alcohol, use a hair dryer to heat pieces that are curved, pull off backing and stick on. The clean surface is very important, I went over surface 3 times to strip off any oil. After all pieces installed I used the hair dryer on some pieces to make sure corners were down. It is important to take your time and "dry fit" pieces for they are unforgiving when stuck.
Take a look:
http://wooddash.com/instalto.html
I bought my car used and the previous owner put these on. I personally hate it. I would love to trade my interior peices to someone who wants this.
You could try and remove, use lighter fluid to loosen the glue and carefully peel off. I have removed some pieces when I first installed that were too much.
Remember the 1st gen used wud and 2nd gen used real American Walnut.
I might try that. My 05 is black with black leather and has the dark burlwood from the factory. This stuff matches but it's just too much. I miss the silver that's behind it. My 03 had the black factory peices with all the silver trim and looked great.
