NickT88LSC
Anyone have a right rear axle for my 2002 Lincoln LS??? I have a vibration/rumbling at 40-50 mph, just had it on the lift and the wheel bearings are not noisy, but the passenger side axle seems bent, it does not spin true, wobbles.
Also, how do these axles come out from the differential??? Are they like a typical Mustang where you have to remove the cover and take the pin out and remove the C-clip or do they just clip in with a clip on the axle where all you would need to do is pry the axle out from the outside???
Thanks
Thanks
