Hey Gang... haven't been on here in a long while. Got a couple of questions to ask:
Will 16 inch 2000 LS rims fit a 2006 LS? I don't know if they changed backspacing...
Does anyone have a scan of the 2006 model year LS brochure? I have through 05, and either lost or never got the 06 one. I'm trying to figure out what options were available...
On a 2000 LS 3.9V8 car, anyone get the error code for an open circuit on the airbag circuit? (I had the car in the air the other day, and I'm betting something twisted ever so slightly and something moved a MM now the system's having a conniption...) What's odd is that when I picked up this error, flashing light on the dash, the traction control light was going nuts as well. It happened about 30 minutes after a gas pump malfunctioned and had gas spraying out of the tank. Car ran fine for about 20 minutes or so then it developed a random miss, only at about 70 mph once or twice, like the traction control kicked in. At first that's what I thought it was, but then it did it again on a section of road that was bone dry. Then the airbag light came on. I'm sure it's a connector issue, I was just looking for hints as to where to start first, if there's one mongo connector that goes bananas once in a while. - otherwise it's back under the car I go, squeezing every connector I can find... yay me!
Also, she's got about 135k on the clock now.
Thanks for the help gang!
