a brake caliper taker offer
lol....so i ask for a caliper tool set....hopefully they let me rent it...i pushed it in back enough with the c clamp when i took it out...... looks like enough space....
The rear ones have to screw back in. If you really pushed it all the way back in, then the caliper is probably damaged.
FYI, I did it using a c clamp, a socket, and a needle nose pliers. Took about 5 minutes extra per side, but it's frustrating.
do you know how much those rubber seals are..... i just need 1.... I did exactly what you guys said.... got that cube thing to push it in.... but that tool just sucked..... man why cant get they just make it easy like the fronts.....
Brake tool... 6 bucks
... and got the proper tool for the job.
I HIGHLY recommend AGAINST this method. more like 5 hours extra per side! That method was absolutely worthless.... for me. I was unable to get enough pressure on the caliper and enough grip to twist it at the same time. Do yourself a favor and rent/borrow that tool. It was truely a miracle how much easier it was.
my grandfather once told me "if you aint got the proper tool for the job, then you aint got no buiness doing the job"
