questions from a friend
Jeffintampa
Tampa ish
1. What is the horse power of the motor in a gen 1 stock
2. What kind of transmission is in it
3. Is it a 8 or 9" rear end
4. What are the ring gears
1. The motor is rated at 280hp for base and 290hp for the LSC models... I would doubt that you will notice any of those 10hp though...
2. 4r70w.... basic 4 speed electronically controlled automatic found in the Mustang, Crown Vic, Grand Marquis, Town Car, F150, E150, Thunderbird, Cougar, and maybe a few other SUV's....
3. 8.8" open differential
4. The Marks came with 3.08's in base models, 3.27's in the LSC's... if you want to know all the availiable ratios... well there are a ton! like 2.xx-7.xx and a ton of diff options.
This is one thing that I will never understand. Why would anyone use an open diff in a modern car is beyond me.
especially one that is pushing 280 at the crank. i do have to say its a ton better than my old cougar. It had the SOHC 4.6L and if there was any water on the road it would spin. havent really driven the Mark in the rain much since i havent been driving it :( but the traction assist should help a bit. I still want a LSD though :(
brandon, psyco is right they are 307's..
I often refer to them as 308's but that is just one of my bad habits from the mustang days.
the minute difference between 307s and 308's is probably about the same as 30PSI and 40PSI in your tires.. the ratio difference is barely measureable and absolutely negligable<sic
I've never seen em listed as 3.07's in any Ford parts list.... but that doesn't regardless of that I'm prolly wrong... but .01 isn't really important lol....
1997 Lincoln Mark VIII Specs, Engine Performance & Other Car ... 3.07:1 axle ratio. -. Four disc brakes including four ventilated discs ... Automatic front and rear suspension levelling. 1997 Lincoln Mark VIII Base Sedan ...
Lincoln Mark VIII - Wikipedia, the free encyclopedia Nov 23, 2008 ... The Mark VIII's rear axle ratio was 3.07:1. The Mark VIII also featured ... Toward the end of Mark VIII production, Lincoln offered two ...
1998 Lincoln Mark VIII Specifications - View New Lincoln Mark VIII ... 1998 Lincoln Mark VIII Handling. -. ABS. -. 3.07:1 axle ratio ... Wishbone front and rear suspension with stabilizer bar independent with air springs ...
(rolls up a dunce cap out of a sheet of paper, then gives it to Brandon to wear for the rest of the day)
no but can i get an apple pie?
YouTube - Family Guy Ding Fries are Done
Ding fries are done
ding fries are done
ding fries are done
ding fries are done
I gotta run
i gotta run
i gotta run
i gotta run
I work at Burger King making flame-broiled whoppers I wear paper hats
Would you like an apple pie with that
Ding fries are done
ding fries are done
ding fries are done
ding fries are done
I gotta run
i gotta run
i gotta run
i gotta run
Don't touch the fries in hot fat it really hurts bad and so do skin grafts
Wait for the bell
cant hear the bell
where is the bell
wait for the bell
Ding fries are done
diiing friiies are dooone
