Air pump
Tiltedhalo
Melbourne
Does anyone know if you cap off the air pump tube inlets if it will set of a cel?
i put on a cobra manifold and blocked off the EGR tube and yes that little orange light has been staring me in the eye ever since
it's watching me
I traced it all down and it looks like its not a monitored system, I need to remove mine to install a steeda timing adjuster. So as long as you leave the pump and wiring intact I dont think I will have a problem.
I was hoping somebody had already removed for like a blower install and could tell me for sure.
Where in the code is it I cant find it, or monitor wiring from the ECM?
Looks to be strictly thermostatic, vacuum control?
Yes it dose give a CEL I had to cut mine off to get the under drive pullies on and it gave me the light until I spliced it back together and cleared the code
