Occasionally overheating, and blowing cold air out my vents when heater is on!!!
bradypc6
lafayette
Anyone know where the thermostat is located on a 2000 LS? Or does anyone know what it could be?
V-8.......The reservoir is full and has been full of coolant, i saw people have said on here that i need to bleed it???? im not sure though what exactly it might be.....i was going to change the thermostat but i didnt want to if that wasnt it!!!!
Go to the top of the page, TECH ARTICLES next to SEARCH go down to LS and draining the cooling system and read the part about bleeding.
definitely needs a good bleed. Follow the directions EXACTLY..and all should be well. Do it on level ground as well.
Could be the DCCV.
If you have never changed it. Then it maybe time too.
I think I'm having the same problem with my 2003 LS V8. Any updates on a fix?
Going on a short trip, 30 minutes one way, and the car said it was overheating and went into the reduced power mode and the check engine light came on.Turned the car off for about 10 minutes, started it up and ran fine the rest of the way, although there were some popping noises and a loud whirring noise of which seemed to be coming from under the dash on the passenger side. On the way back home the car overheated again without even leaving the city. After getting a friend to come follow me in case I had problems decided to drive it home. The some noises were present but it never overheated. The temperature gauge rose to about almost overheating but then suddenly dropped to half. The heat didn't work either going back home. Felt like the car was just pushing air. Eventually after about 15 minutes the air was a bit warmer which is I'm guessing was from engine heat. It was by no means hot as it usually is. Anyways, after getting home made a trip to autozone to get the sensor read. It overheated twice, once each way to and from Autozone, a five minute trip. One time after turning it off steam came from under the hood. Only let the car sit a couple minutes this time. The code was P1299. What is most likely the problem? I've read thermostat and to check the coolant. Autozone also suggests failed cylinder head temperature sensor.
You have an air bubble in the system. Bleed it THOROUGHLY and your problem most likely will go away. If it doesnt, next step is to replace the thermostat..followed by a bleed again.
