sigh.... not again...
It is physically impossible to create energy. The only way hydrogen assisted vehicles can work is if the hydrogen comes from another source of energy besides the engine's (solar, hydrogen stored in tank, etc.). Simply put, you cant expect to break water apart, then get more energy from putting it back together.
Oh you guys need to go back to science class. The HHO systems that people talk about do not claim to create energy. The claim is that Hydrogen is "unlocked" in molecular form from H2O molecules which is totally possible from a scientific standpoint. It is called catalyst for a reason. Use a smaller amount of energy to start a chain reaction that in turn releases a larger amount of energy that was otherwise locked up in molecular form. I am not saying whether these HHO systems work or not but your reasoning for rebuttal is WAY off. From a purely scientific standpoint HHO systems theoretically make sense. You are also flawed in the thinking that you cannot break a molecule apart and make power and then reassemble something similar to it in another completely separate reaction and generate power also. Look at the basis for nuclear fission and then look at nuclear fusion... Very similar concept. Fission unlocks allot of power and fusion unlocks even more.
Guys it totally cool if you want to debate this stuff till the cows come home but please at least have a general understanding of the science behind it when telling others they are wrong. Many people only half-slept through science class in high school and tend to misinterpret the wording behind some of the common "laws" of it.
and so far this particular system is functioning as theorized, over the last 15 (20g) tanks of fuel his truck has averaged about 21-22 mpg, thus a raise from 14-15, its doing something, not much but something, and I assure you this particular system is Far more complex than those jank ass kits you see on ebay lol
its not "creating" matter or energy, its breaking down water into a burnable substance, that DISPLACES a small amount of fuel
true it is in-effecient but the result is the same, its displacing petrolium as a burnable fuel
yes underneith it all it does take fuel to seperate hydrogen from water but the gasoline off-set, meaning the gasoline it takes to produce x amount of hydrogen is less than x amount of hydrogen displaces in fuel, so say, x = 100% of the liquid fuel volume required to run the vehicle, and the amount of x used to create the electrical system amperage to seperate water into hydrogen is 1% so now you have more than the origional amount of fuel x required to run the vehicle so in reality you have x+1 percent of fuel going into the chambers, well that 1% of fuel required to seperate the water yields H amount of hydrogen, so lets say volumetricly H is equal to roughly 10% of x, because hydrogen is a gas so your still x-9 in the green, because gas Per cc has a higher potential energy release than hydrogen, so assuming for :q:q:q:qs n grins that gasoline has 3 times the potential energy release of hydrogen meaning 1cc of gas = 3cc of hydrogen for the same chemical energy release 1% gas used = 3% hydrogen offered to burn, yielding the same energy release from the combustion event, yielding a 20% reduction in the amount of gasoline used, even though the combustion event is the same, and there is gasoline used, the vaporous hydrogen displaces more fuel volume than the liquid fuel.... or maybe it could be that the vaporous hydrogen displaces oxygen in the cylinders thus resulting in a rich condition, allowing the pcm to pull back fuel trims lol
untrue, oxygen is consumed in hydrogen combustion. See equation:a byproduct of hydrogen being burned is oxygen
the stored energy that is released from the water is then burned, in the form of hydrogen
so basically your taking energy, using it to seperate water into h & o, and then returning it in the form of a fuel, that isnt gasoline.
I should hope that you as a tuner is not advocating these kits and should know that sniping the wires to your O2 and tossing in a resistor is only asking for damage; in and of itself should be a reason to steer people away from these kits.
btw... just to clarify...
Nuclear Fission is the splitting of an atomic nucleus resulting in the release of large amounts of energy when a heavy nucleus is present...
Nuclear Fusion is the union of atomic nuclei to form heavier nuclei resulting in the release of enormous quantities of energy when certain light elements unite
A key thing to note here is that Fusion is the inverse to fission. Fission is splitting a single nucleus where fusion is uniting two or more "nucleuses" (nuclei is the correct plural word)... However, the weight of the nuclei involved determine weather one of the processes will absorb or produce energy. Meaning, in Fusion if X and Y creates energy... fission to split the resulting nucleus, it will absorb energy. Hence fourth the laws of matter still apply 100%; you aren't able to split a nucleus and get energy... then put it back together again... and get energy. Doesn't work like that.
Combustion on the other hand is rapid oxidation.
Fission and Fusion are simply the inverse of each other, not only in terms of splitting and uniting... but also in terms of energy production and energy absorption... combustion isn't even remotely related to the two as it is a chemical reaction where whole molecules are exchanged... in tact and unchanged... unlike the other two which are nuclear reactions happening at an atomic level creating massive changes to the elements involved.
Eric, if I'm off on any of this stuff... let me know; I'm just a trigger puller... not a scientist!
ILLS... I've got to get my digs in when I can... But it looks like you're the one that needs to go back to science class!![]()
