Because, nothing was "soaring" -- One thing went up, but another went down. And dont give me any blame for the democrats. I've said it before, GW and the republicans had 6 years to fix anything they thought was wrong. They clearly didnt fix anything and/or made things fall apart.
Joey, you respond, yet you don't argue anything.
You're saying the economy has not been strong.
Based on what?
I may be giving you too much credit if I presume you can even think of one section of the economy that was down, while the rest of it was up..
The reality is, the PERCEPTION of the economy has been bad, but that's the result of bad reporting.
And about the Republicans having six years to fix things.
That's nonsense.
First- the Republicans DID NOT control the Senate for six years.
Second- the majorities they held have been so slim that they were ineffective. Using your logic, Bush shouldn't have had any trouble getting his political and judicial appointments confirmed, but he did.
And you're also failing to note the REPUBLICANS ARE PISSED OFF WITH THE CONGRESSIONAL REPUBLICANS. They were ineffective and failed to govern by the rules they traditionally support.
The problem is, despite this, those same failures are STILL BETTER than the absolutely insanity that is the Democrat party. That's really scary.
You also said they "clearly didn't fix anything." That's a stupid statement, because I can't point to something that didn't happen and demonstrate that it's because of what they did do. The reality is, many of the economic policies the Republicans did pass, on the good days, helped keep the economy strong for the past seven years. They prevented a severe cyclical recession after the tech bubble burst and after 9/11.
So, if you ever get around to directly answering a challenge-
specifically, what sectors of the economy have trended badly the past few years?
And what economic policies do you think are necessary for a strong and healthy economy? Which ones are actively supported by the DNC?
Also, which Republican policies caused things to "fall apart." And what specifically has fallen apart?
