k9t8m
Rollin' Twankies
I like my $6 spedo gear. only takes about 2 minutes 2 change.
I installed it with the new tranny. No one at the shop wanted to "drill the hole" - so I just emptied the console, grabbed the cordless drill and popped a hole down through the middle of the console and shoved the wires down through and said "There - hook it up". LOL
The power was taken from the tranny harness, that's about the extent I know - Oh, and we had to extend a couple wires in the harness to reach.
Sorry, no pics.
I read someone else put theirs in the console area in front of the shifter and ran the wires through the same grommet the tranny wiring has in the shifter area and they did not have any issues?
to long ago to remenber how we did the 94 but if you can reach the dip switches use a hand held gps to set them it will get it damm close to right. 4tents of a mile in 1000. that was varified by a flying trip to huntsville al and back to beardstown. when you switch the dip switches while moving it sure gives the speedometer a work out . take care have to make a run to ham lake mn. an right back . jd
The shifts/scheduling of the trans is determined by many inputs (I was going to list them and the symtoms of each, but the list is long!!!)
Transmission Speed Sensor (TSS)
The transmission speed sensor (TSS) is a magnetic pickup, located at the output shaft ring gear that sends a signal to the PCM to indicate transmission output shaft speed.
Transmission Function:
Torque converter clutch control, shift scheduling, used in determining EPC pressure.
Symptoms:
No converter engagements, harsh shifts, abnormal shift schedules.
DTC: 639
Vehicle Speed Sensor (VSS)
The vehicle speed sensor (VSS) is a magnetic pickup that sends a signal to the PCM. This VSS signal tells the PCM vehicle speed.
Modifies upshift schedules.
Symptoms: Shift engagement/disengagement (hunting) on grades.
DTC: 452
