DTC P1131 - Lack of Upstream Heated Oxygen Sensor Switch
mark0101
Jax, FL
DTC P1131 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
So which O2 sensors do I need to replace?
I would look for vacuum leaks before I change the O2 sensor.
Well I am getting bad gas mileage, so I am pretty sure it needs an O2 senors. So does it need the ones in the front or the back? It has 110K.
does the code say if its pre or post cat?
what I posted is what it says on the websites for the code DTC p1131. I am guessing its the one before the cats, but I want to know which one before I replace them.
