got the fuel pump in and the hole all closed up but stupid me forgot to take pics. lol once I start working its a one track mind.
but i made some marks on the pic that was already posted to help aid others planing on taking the same route.
since the pic is a gen 2 its a little different, so I put the circle aproxamatly where the pump is on the gen ones. I cut the hole (marked in blue) with a air hack saw. and cut the blade really short. be very very careful while doing this you do not want the blade to brake threw the back side of the floor where i marked in red there is less then a 16th of an inch between the floor and the gas tank. be careful and take your time.
when cutting the hole do not cut out the seat clip. it takes a little finness to get the pump around it but its possible.
now for the patch.
its much easyer to reuse the part you cut out. since the floor is so close in some parts its not a simple as drilling and riviting. and of course the pice only fits in the hole. it dosnt cover it.
so go to a local hardware or car auto store and find some inch wide strips of steel. either 18 or 20 guage. clean the parch panel. (this can be difficult)
now here is the important part. on the pannel where I marked the compleat side red. you want to weld a strip across that side on the underside of your patch leaving about half of the strip hanging off. now you want to frame teh rest of your patch pannel but welding the rest of the strips on the top side (this is very important). now clean up and paint your pice top and bottom (any spray paint will do) you will never see it you just want to keep it from rusting.
your patch should be a perfiect fit. the side marked with red your framing strip will slide under the floor and the rest of the frame will sit on top of the floor. it should fit snug as long as you didnt warp it while welding.
use a seam sealer available at any auto parts store run a bead around your frame put your patch in place and drill hole and riving to hold in place MAKE SURE YOU MARK ANY PLACES THAT THE TANK OR LINES ARE TO CLOSE TO ALOW FOR DRILLING AND RIVITING. and obviosly dont drill or rivit there. put a little more seam sealer around the edge of your patch to keep water out. let it dry and ad a coat of robber based rocker guard (seals everything up nice.) let dry again and put the seat back in.
the best thing about doing it this way instead of dropping the tank is that if you ever have a fuel pump issue like it quits while your on a trip and 2 hours from home (lol been there done that)
the pump can be now changed with simple hand tools and you can avoid large tow and repair bills in order to get home
