Pleas point it out...
It's right there. Can you see where my finger's pointing?![]()
KS
The new thermostat is not that expensive. If you're going to bother opening up the housing and deal with bleeding the air out of the system you might as well drop the $20 and just replace the thermostat. Then there is no worry whether it's working quite right or not.
Well I got the thermostat out but broke the thermostat housing in the process. I am in the middle of trying to replace that but the 2 bolts in the back are IMPOSSIBLE to loosen or tighten back down. I had to break the remaining housing off the enging to get the 2 back screws off. Great idea, except it doesnt help me with getting them back on with the new housing I bought! Any ideas?????![]()
As far as the thermostat goes, my old one was def bad. I put both in a pot of boiling water and now I see what it should have been doing.
