factory emblems
cf99gt
waco
i did a search and didnt see any info about the factory emblems. im wondering how the ones on the back are attached and if they can be removed ? thanks guys
they are held on with double sided foam emblem tape. you can peel them right off, i usually use a small flathead to get it started gently then use my fingers to get it off.
awesome. what is the best thing to use to get any of the sticky film off if there is some ?
I used fishing like to take mine off & clear rtv to put them back on after I cleaned them all up & took the sticky tape crap off.
Which year? If 93 to 96 I am pretty sure holes are used to locate when installed.
Not sure if you understood what turbo said. You can use dental floss or fishing line and pull and 'saw' through the tape on the back. No dents or broken emblems from prying.
like unity said, there are holes and tabs so floss wont work it its a gen I, other wise a thin plasic puddy knike and a heat gun works well for anything stuck on the car.
crap. mines a gen 1. id have to cover the holes somehow til the car got repainted in the future. then they could be filled in first
Speed Demon: Not sure if you understood what turbo said.
Yeah I can't type or spell right half of the time! I meant to say fishing line. Duh:slam
