I have had the same problem for a couple of years on my '96 Mark. It would not "overheat", but it would get to the top of the Normal section, just under the "N". I flushed and burped the system several times to no avail. Even had a shop install a new thermostat because I didn't want to mess with it. Didn't help. The cooling fan was working fine and there was no air in the system that I could see. Recently, it had begun to get worse and I started getting a "low coolant" warning, even though the reservoir was completely full. The low coolant turned out to be too much water and not enough anitfreeze. It turns out that the little float in the reservoir is apparently designed to float only when there is enough anitfreeze in the system. When there is too much water, it will sink. Neato huh? Anyway, I found a Stant 160 degree thermostat for a Mustang Cobra on Ebay and installed it. Since installing the new T-stat, the thing has run great and the guage barely gets to the bottom of the "M" on 90 degree days with the AC at full blast. Increrdible. I have always thought that a 195 degree factory thermostat is waaaay too hot for an aluminum block engine. Anyway, this may not work for everyone, but it sure worked for me. Hope this helps. And remember, when you replace the t-stat, you will get antifreeze all over you and everything around you. And you will have to refill the system and burp it again.
