mespock
Marxists - Socialists
For everyone looking to purchase a cold air box but can't find one or afford one. Here is a simply idea to solve the problem.
First I looked at cold air systems for Mustangs and noticed that most only have a small shield that shrouds the cone filter. So if this is suppose to supply the air intake with colder air then I figured all you need is a block or air dam to block most of the engine heat.
So I took a pieces of cardboard and I placed them in position to fill the area between the engine and the area that houses the air filter.
Then I taped the pieces together and used bondo to make the dam solid. Went to my local parts store and purchased a can of DK automotive paint (same color as my car).
Used a piece of a door gasket to help make a better seal at the top of the dam with the hood.
No I know there will still be slight leaks of engine air but it should be many times better than no shield, and it cost me less than $20.
I know there are many on here who can do a better job, so go ahead and improve this idea.
Oh and I made a template of the shield. So it is available for anyone who would like to try. Best is I will not charge you for the template.
Now my question is... I had removed the air silencer from the front of the car. If I trim off the extra lung on the damn silencer, would this allow for colder air to be better forced up? My thought is ford did design the intake to pull in air or did they do a $hitty job that makes it worthless?
