4.10 gears
96mark8
north pole
I have a standered 96 mark can i fit 4.10's in my stock differential case or do i need a bigger case?
thanks
The stock diff is an open carrier. I'd suggest getting a Trac-Lok unit or better if your going to swap gears, or you'll really have a one-wheel peeler!
Yes, do the trac-lok as well, you might as well since you will have to get the carrier out anyways. i am doing mine on friday. hopefully i will do a writeup. I got my full kit from Max at Five Star Ford. Excellent price and great service..
Ditto on everything except I hope to have mine done by next week.
And it's a good idea to get a tune to adjust the shift schedule to go with the gears.
ok so it has to be out of a irs cobra?
and do u guys think 4.10's would work good with a t56?
yes and no...............
99 cobra yes, later years, no
I dunno really about the gears, The T56 for the cobras don't have much difference in the OD ratios.
The t56 is like .62
the t45 is .68
If anything they would work better with the T45, because of the wider ratios between gears. (less shifting)
IF you could get an early Fbody T56, you can get a .5 over drive ratio which would be killer with 4.10's.
mike
will a trak-lock out of a 01 gt stang work?
Technically yes but have fun trying to get the axles out again.
Unless you you already have one or maybe if your upgrading to 03 Cobra clutches would just get a new one from Max. I think it was under $200
yea i saw that they cost $192 i guess i will just get one of those
No.
The spider gears are different between the Solid axles and IRS
I have seen some Trak-Loc's out of newer SRA's that have beveled gears like our IRS's so if you see one for the right price just look at the side gears
best pic I could find in short time
Hrm,
I cant really see anything in those...... Ill look around on google for a pic.
If anything I have a precision lathe at work that I can use, I just need to know what needs done........
Mike
if you don't have anny luck I will try tp post better pics tonight now I am on my way to power tour
