help mystery codes pulled from 98 lsc
kracker
Shalimar, Florida
i pulled to codes today and have no clue to what they mean nor do they make sense due to there format. first code is P2BDD fuel air metering Auxiliary emissions control. and the second code is P04F4 Auxiliary emissions control Help
thats not the codes, i dunno what that would be, how did you pull them it should be something like po301 (thats a cyl 1 missfire)
i know what the codes are supposed to be like but lincoln and cadillac has vehicle specefic code that are a different format. i have already contacted the dealer and they want $150 to scann get the same coe and then tell me what it is i used two different scanners a memo-scan which is mine and a scantron obdII & can scanners
go to autozone, they will pull them for free, then you can just leave before they sell you some garbage
i pulled the code from a parts store these are the codes that 3 different obdII / CAN scanners have giving me i know what the codes are and what area they are from but the autoparts store even told me that it is a vehicle specific code but thank you
Kracker, you need to understand something, Chickenviii is a ford tech!
if he doesnt know the codes ,something is wrong.
gotcha my bad so maybe it's my computer but i am sure since he is a tech he is definatly more knowlegable than i am on this. I am just confused on the codes like i had mentioned earlier i used 3 different scanners one from orielly's and two different models of act tron scanners got the same code the act trons gave me a description but nothing more than what i posted ok so the codes are bogus. so now i have heard of vehicle specific codes is it possible that the is the way that tose scanners interpet the codes and only a deal can pull the correct codes
yup moes8 gave me up, ive never herd of a code only a dealer can pull either very odd, only advice i can give is to dig up some cash and go to a dealer and tell them you just need them pulled and see what you got
